rough idle problems
Old Jan 6, 2008 | 02:01 PM
seventhgear's Avatar
hanglike sleeve of wizard
Default rough idle problems
i have a 90 crx b16a-Turbo
when my car is cold started it idles rough for a while and the throttle response is sluggish and sometimes wants to shut off completely. if i floor it while cold it will fall on its face with power and bog severely. could this be a coolant temp sensor prob?
image removed from your sig...see forum rules
Old Jan 8, 2008 | 05:04 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
It does this ONLY when its cold?
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Jan 8, 2008 | 05:44 PM
itsslow's Avatar
I-VTEC, do you?
Why would you beat on it if its not warmed up yet?
Could be the coolant temp sensor, could be the IACV, could be many things.
My advise would be wait till its completly warm before you beat on it. Just wait till its warmed up first. Wake up 2 mins earlier and start the car up.
Old Jan 8, 2008 | 06:07 PM
StreetBlitz's Avatar
B Tuned CRX
fuel pressure?
Old Jan 9, 2008 | 11:27 AM
nocomply540's Avatar
is retired...
^I was gonna recomend that too...my gauge was busted so I put a pressure gauge to get a quick reading and I was running 28psi and bumped it up to 48 and it starts ALOT better. A quick test someone told me to try once was to take off your intake piping and plug the holes inside the throttle body one at a time...if it idles right when you plug up the top one I believe it's the IACV if the bottom hole corrects the idle then it's the fast idle control sol??<----forget what it's called exactly but its the sensor under the throttlebody...
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Jan 9, 2008 | 12:05 PM
96ek's Avatar
Check engine light on??
Old Jan 9, 2008 | 01:15 PM
Derka's Avatar
TR Balla Donor Supreme
If it was a coolant temp sensor problem, i think it would happen all the time. If the sensor is bad, it wouldnt function like that only when it was cold. I think..
1998 crv daily beater
Old Jan 10, 2008 | 07:54 PM
doesnt mater if i try to beat on it when its cold.... i start the car a few mins b4 i leave, dont think im a complete dumbass, but my car stays cold for a very long time, although everything is functional, even in the hott summer days. i have to floor it just to go, no hard acceleration. now it is picking and choosing when it wants to do it. once i shift thru 1st and 2nd and shift to 3rd the hesitation usually dissapates.
Old Jan 10, 2008 | 07:58 PM
EfWorld's Avatar
Id say take a look at you TPS, proboly on its way out
