E-Brake Light----Need Insight
Old Jan 3, 2008 | 06:43 PM
HaZed's Avatar
No more Vtec!
Default E-Brake Light----Need Insight
So today when i turned on my car, i noticed the e brake light didnt go off when i put it down....it stayed on for about 20 min and everytime i came to a red light and hit my footbreak, the light would go off but as soon as i let off the brake the ebrake light came back on! i tried pulling the ebrake up and down a number of times and even tried slammin it down but the light stayed on...it eventually went off and stayed off... i have no idea what that means-if anything-and need some insight if anybody knows whats up! thanks!
Old Jan 3, 2008 | 06:48 PM
opiumdaze's Avatar
how about checking your brake fluid? low fluid would cause the "brake" light to come on when the car is moving.
Old Jan 3, 2008 | 06:59 PM
HaZed's Avatar
No more Vtec!
Its not my brake fluid....i checked it and both of them are full....
Old Jan 3, 2008 | 07:06 PM
Invader_Zim's Avatar
Typical TR Asshole
could be a short in the wiring... check your wiring and stuff
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Jan 3, 2008 | 08:18 PM
OMGVTEC's Avatar
Retired Moderαtor
1. Could be the ebrake switch, you would have to take off the cover to see this, could be stuck down
2. Check to see if you have either a leaky wheel cylinder, caliber or brakeline.
Check to see if the brake switch on your brake pedal is bad. Also check to see if the master cylinder is leaking into the the brake booster
3. If those are OK, then your proportional valve most likely has to be replaced, and then bleed the brakes with the key on but not running
Old Jan 3, 2008 | 09:02 PM
steve2323's Avatar
240 FTW!
check your wheel cylinders that happened to me with a car i had it wuz the cylinders
Old Jan 5, 2008 | 08:45 PM
Sohcvtec1995's Avatar
Honda Guru
its a common problem on integras, yuor cap sensor thingy maybe getting stuck, take it off and lube it up
screwed by wb_map3
https://www.tamparacing.com/forums/b...pinions-9.html
1995 Turbo Ex Coupe
14.2 @99 8psi, street tire full interior with lots of crap in the car. SOLD
03 GSXR 600 Toy SOLD
1994 Acura Integra Sedan Daily SOLD
1993 Honda Civic Si PArted and Sold
07 GSXR 600
c280 Daily
Old Jan 5, 2008 | 08:48 PM
Typical TR Asshole
updates....
