car wont start
car wont start
Yeah I have a 95 civic ex with the z6 motor. I was driving the car and it shut off on me. I'm getting fuel but theres no spark at all. But we tested the coil in the distributor and it still good. So what could be the problem with the car. Do I have to replace the dizzy or could there be something else causeing the car not to start. Timeing belt also good.
I had that problem and it was still the coil it tested good but when i replaced it it fired right up.. It could also be your igniter... Try using someone elses Dizzy if you can get your hands on one for a few minutes and see if thats the problem
You can test your ignitor and your ignition coil if you have a haynes manual. Also another culprit might be the grounding wire that comes of the distributor harness and bolts up to the transmission. Make sure its tight. If you still can't figure it out pm me your number maybe I can help you out.
