Skunk 2 Mani
Old Dec 22, 2007 | 11:36 AM
mondo375's Avatar
Default Skunk 2 Mani
Its the Pro-Series. I noticed some of the hoses on the Manifold are in a different area then that on a z6 manifold. Can someone help me out and identify where each hose goes?
*edit* After further research, I found the following.
I only need to know where Pink goes go? I know they are coolant lines and run to the FITV of the Throttle Body, but does it matter which one goes where?
Also my z6 throttle body should bolt right up correct? It currently has an LS Throttle body which i don't mind using but the FITV is backwards as compared to the z6 TB if i recall correctly.
thanks!
Mondo
Old Dec 23, 2007 | 04:54 PM
mondo375's Avatar
guess ill blindly attempt it tommorrow lol
