tranny problems
Old Dec 19, 2007 | 05:12 AM
dippincrx's Avatar
save the s.o.h.c
Default tranny problems
ok heres the deal. since this cold wether ive started to hears some tranny noises. sounds like a bad throwout bearing. but noticed even w/ the clutch pushed in coasting at about 30ish the noise is still there. it has that dry bearing noise to it. no vibrations, trannys shift perfect just makes that noise. could it be the input shaft bearing or pilot bearing? rep given for any help thanks
Old Dec 19, 2007 | 03:00 PM
Try not pushing in the clutch and with the car in neutral, engine on.
Try not pushing in the clutch and in neutral, engine off.
Try pushing in the clutch and in neutral engine off.
We already know your results so far with clutch pushed in
and coasting. Tell us next which above is noisest.
Tell us which is quieter. Tell us which makes the same amount of
noise.-Bob
Old Dec 19, 2007 | 09:31 PM
ATI LUDE's Avatar
GEEZER
I have a brand new flywheel and complete new clutch assembly on my prelude and in cold weather with engine on and in neutral I also can hear a very slight noise that goes away. My mx3 also does this as well.
Wilma Northrup: Get out of my way Henry, or I swear to god you will be wearing your balls for earrings!
JUST TELL IT TO CALL YA BILLY!!!
Old Dec 20, 2007 | 05:24 AM
dippincrx's Avatar
save the s.o.h.c
noise.-Bob
not pushing the clutch w/ the engine on in neutral its really noisy loudest it gets and when i push in the clutch it goes away. im pretty sure it thes t/o bearing. and of course its as quiet as can be w/ engine off
Old Dec 20, 2007 | 09:51 PM
ATI LUDE's Avatar
GEEZER
(not pushing the clutch w/ the engine on in neutral its really noisy loudest it gets and when i push in the clutch it goes away. im pretty sure it thes t/o bearing. and of course its as quiet as can be w/ engine off )
My mx3 makes one hell of a racket in this condition
