clutch kit on a cable tranny
Generally, if the clutch/disc/pressure plate is designed for
a particular engine/flywheel combination, it may not matter whether it is
disengaged with a hydraulic cylinder or a cable.
If the clutch disc splines and the tranny input shaft splines match, it may not matter whether it is shifted with a rod or a cable.
I would check at the a-parts store to see what engine combinations the kit is designed for.-Bob
thnx will do that
