torqe spec on eagle rods
Old Nov 30, 2007 | 10:15 PM
civic4's Avatar
Default torqe spec on eagle rods
its a b16a with eagle rods.where putting a new bearing on the motor.what is the torqe spec on the eagle rods ,i think the stock spec its a little different.thanks
Old Dec 1, 2007 | 09:45 PM
T4eg's Avatar
depending on rod bolt... 3/8 is 43ftlbs 5/16 is 28ftlbs
Old Dec 2, 2007 | 01:19 PM
civic4's Avatar
its a arp bolt
Old Dec 2, 2007 | 01:26 PM
sleepinsol's Avatar
starting over
i would either call arp or eagle n they can tell u.
Old Dec 2, 2007 | 01:37 PM
Alpha's Avatar
ARP makes both those sizes. You most likely have 3/8 bolts. Eagle use to use 5/16 a long time ago. 45ft/lbs with 30-wt oil and 35ft/lbs with ARP Moly. Torque them in two step increments
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 2, 2007 | 01:51 PM
civic4's Avatar
i went to double check it again its a arp bolt and it say arp 2000 right on the bolt and also its a 12 point with 11 mm.
Old Dec 2, 2007 | 02:13 PM
T4eg's Avatar
Originally Posted by civic4
its a arp bolt
i know its a arp rodbolt, i was meaning depending on the size
3/8 arp2000 7/16 bolt head 43ftlbs
5/16 arp2000 3/8 bolt head 28ftlbs
Old Dec 2, 2007 | 02:18 PM
civic4's Avatar
ok thanks
Old Dec 3, 2007 | 08:45 AM
J-AL"187"'s Avatar
J.Algarin
Ok you'll need a TORQUE wrench
2 Set's of bolts
A good set of taps
Cell phone to call PAT
Start torque-en till you get to the point before they snap. Keep going a lil more at a time. Don't rush this part take ur time. Once you finally broke em off; Drill em out and tap them. MAKE SURE TO CLEAN OUT ALL THE METAL LEFT BEHIND REALLY REALLY GOOD. Then get another set and start torque-en em and stop right before that point in the last step were they snapped! Shit really ain't that hard. Fukk you even spelled torque wrong dumbass!!!!!!!
And never forget
http://i129.photobucket.com/albums/p...hsignhonda.jpg
(JOSH)
Old Dec 3, 2007 | 09:03 AM
rangcrx's Avatar
engine building &best
2 Set's of bolts
A good set of taps
And never forget
just Tq them to 34fLb
i love AUTOZONE
