wiring a switch for a radar detector
Use a vacant fuse under the dash, use a double pole-double throw switch. One side is hot, other side is ground.
Take power from the fuse to the detector hot wire.
Take ground from a good ground to the detector ground wire.
Hide the switch, hide all wiring. Hide the detector,
even if you have to make a bracket.-Bob
Quote:
Originally Posted:
What's the easiest way to hardwire the Radar with the cutoff switch?
Quote:
Originally Posted:
Quote:
Originally Posted:
Quote:
Originally Posted:
