93' accord starts then stalls
Old Nov 23, 2007 | 04:36 PM
RubberBerner's Avatar
Sideways Maffia
Default 93' accord starts then stalls
Sometimes car will start, and run for a minute or two, but sometimes stalls immediately. It started the other night when i filled it up with gas, and then wouldn't start. I didn't overfill it, gave it a minute after it didn't start, and then it cranked right up and drove fine. I replaced the ignition module about a year ago, because it would just crank and not fire. has anybody had this problem?
NOBAMA!
Old Nov 23, 2007 | 05:40 PM
justlatino's Avatar
justlatino
water in tank..........put some alcohol to mix with the gas but if it to much u have to drain the tank and cleaner, some marine product are very good when water its present............just a guess
Old Nov 23, 2007 | 05:41 PM
92 CiviC H/B's Avatar
-Proud Croatian-
my friend had a same problem on his civic every time he puts gas in it the car wouldn't start.he changed the battery and that fixed the problem.
my 91 integra did the same and it sputtered a lot changed the dist and it helped.
hope u get it running properly.
.TR's OldSkool DA Crew Member #14.
Old Nov 24, 2007 | 03:56 AM
Old Renegade's Avatar
Cool Runnings
maybe your fuel pump is going out. what accord is that? dx, lx or ex?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Nov 24, 2007 | 12:20 PM
Sideways Maffia
Its a coupe. i got it to mess up today, the gas fill-up had nothing to do with it. I tested for spark and it would run for 2 minutes, then the spark would cut out-and stall. I tested what it said in the chiltons manual...and passed all the tests saying the tdc/cyl/crank sensors are all good. Proper voltage (b+) is getting to the yellow wire at the 2p connector, and 10v @ terminal A of the 8p connector of the distributor. Now it wants me to test for certain voltages at the ECU...but i'm thinking its more along the lines of a distributor/or sensor/ or coil problem. I know they had a campaign to replace the distributors for those years, but she already had a distributor put in about 10k miles ago. Any help? any one?
**EDIT**:Has anyone ever experienced any issues with C209, c115, c131, or c116 pin tensions? the shop manual says it could be due to poor connections in one of those connectors, but they looked ok to me.
NOBAMA!
Old Nov 24, 2007 | 12:55 PM
-Proud Croatian-
i think its the distributor.
Old Nov 25, 2007 | 07:31 PM
Sideways Maffia
Cool
It was the distributor, tested out one from my brothers old car, ran fine. Distributor has all the sensors in it, and has to be replaced as a unit. Went and got a reman'd one from advanced for $148 with no discount, napa wanted $203 with my discount for my shop having an account with them. I thought honda tech would be able to help me, but i guess not many tech's here
NOBAMA!
Old Nov 25, 2007 | 07:40 PM
Invader_Zim's Avatar
Typical TR Asshole
glad to hear you got the problem fixed man, having your car mess up sucks!
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Nov 25, 2007 | 08:34 PM
izzyaccord's Avatar
i was gonna guess distributer its cuts off when it gets hot and cranks when its cold
Old Nov 26, 2007 | 08:32 AM
Default not many tech's here???????
RubberBerner,
Thanks for posting what you found.
All our tech guys are volunteers, and at 8:36 on a Friday night, they do fun things like take a few hours for some really slow, high-quality sex with women who really appreciate it several times a night!.....................
That's my story and I'm sticking to it! -Bob
