What seats fit in a 95 civic???
Just curious, what seats front & back would easily fit into a 95 civic 4 door???
All help will be rep'd
ಠ_ಠ Haters gonna hate ಠ_ಠ
actually the teg 4 dr back seat bolts up but I am pretty sure that there is a gap somewhere. I am curious to see if a 4dr back seat from 96+ civic could bolt in....in theory the two should be roughly the same size. As for the teg fronts, you need to swap the rails as the bolts wont line up correctly if you use the teg rails (put the civic trails onto the teg seats). I think prelude fronts can be made to fit and del sol fronts work too. S2000 and RSX seats need a little work I believe. Not sure off hand though.
Okay, I did some research and here is what I found. It would seem that integra 4dr seats will fit just about perfect. Here is a guy in thailand that has ITR 4dr (db
rears in his 4 door. They look sick....hella sick... here is the url/link: Honda-Tech.com: Appearance / Cosmetic: -= A Genuine JDM EG9 SiR Shell + 98 Spec Internals =- [56K Go Play]
Also, if you need some ideas about what soem clean 4drs can look like check this thread out. There is a lot of pages but it is worth it to browse bro. Check it out if you want.
Honda-Tech.com: Appearance / Cosmetic: ....::
Official Ferio EG Squad |:::....
