Low idle
Old Nov 15, 2007 | 04:30 PM
Invader_Zim's Avatar
Typical TR Asshole
Default Low idle
95 civic with a stock d15b7 when i come to a stop the car starts idling low and running rough, i think it has to do with the vaccume line from the intake to the valve cover. if i hook that hose back up should that solve the problem??
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Nov 18, 2007 | 05:28 AM
Typical TR Asshole
ttt anyone?
Old Nov 18, 2007 | 07:20 AM
rangcrx's Avatar
engine building &best
unplug your o2 sensor see what happens..does your check engine light come on after a bit of driving?
i love AUTOZONE
Old Nov 18, 2007 | 08:32 AM
stockCRXsi's Avatar
the line from the intake to the valve cover is not causing that problem. give more details of the problem. is it when the car is warm only? does it idle low when you start the car? is it only after you drive and stop? any CELs?
Old Nov 18, 2007 | 11:30 AM
Typical TR Asshole
ok, the check engine light is always on, the low idle is after the car warms up it dips down to almost 500 rpm's when i come to a stop
Old Nov 18, 2007 | 12:12 PM
freakasis's Avatar
if the check engine light is on thats your problem. fix it. wanna know how?
Reading error codes on 92-95 Civics (OBD-I Hondas)
Old Nov 18, 2007 | 12:52 PM
rangcrx's Avatar
sounds like o2 sensor then
i love AUTOZONE
Old Nov 19, 2007 | 07:31 AM
Typical TR Asshole
well i got the ecu code for the check engine light and it was the Automatic Transmission Lock Up Control Solenoid Valve. Anyone know where that is and would that cause low idle?
and thanks for the link, it was a great help
Old Nov 19, 2007 | 07:45 AM
rangcrx's Avatar
sounds like you have a automatic Ecu on a 5speed did you do a conversion
i love AUTOZONE
Old Nov 19, 2007 | 08:09 AM
Typical TR Asshole
actually, no. the car is still automatic, i just changed the engine
