96-98..99-00 civics radiator support
on
can some 1 tell me if theres any diferences between 96-98 and 99-00 civics radiator support??
1-94 integra (gsr)sold
2-95 integra (ls) rip
3-99 civic ex coupe(b16a2) rip
4-97 civic ex coupe(b18c1) traded
5-96 midori ek hatch(lsv) sold
6-96 midori ek hatch(b18c1) d-d
not sure, but why? cant you buy a new one for about $100? i'm just thinking i'd rather buy a new one, that way i know there wont be any fitment/install issues.....i just always order those new just in case and also bc they're usually not that expensive.
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
meows meows
I believe they are different, something with the bumper or some ish.
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
on
i have a 96-98 civc and the radiator support is bad, and i have a 99-00 radiator support and its brand new im not sure if is the same thats why im askin
okay, so the upper and lower tie bars are the same as well as the vertical (latch) support.
so, its the same except for the side supports are different.
hope that helps!
hope that helps!
meows meows
meows meows
on
wat do u mean by side supports
this isnt for a civic, its just what i had handy but you'll get the idea.....
see #2 and #7, those are the side supports
you can buy # 10 as an assembly or you can just buy the parts you need
for the 2 different gen civics, the assembly is different bc the side supports are different.
the upper and lower tie bars as well as the center/latch support are the same though.
i'm assuming you're just looking for the upper tie bar though as thats whats most likely damaged, or at least thats what i replace most.
meows meows
meows meows
on
^so u think the 99-00 support wont work on a 96-98 ????
