Tranny Swap
Old Nov 10, 2007 | 07:13 PM
Pepsicola1489's Avatar
Control_x3
Default Tranny Swap
IDK about 8 months ago I did a tranny swap on my Honda and have yet to convert the wiring for the shifter (P,R,D,1,2) for a Standard setting. I have it set right now that the car reads in Park so it runs. I would like to convert the wiring to regular standard setup so my reverse lights work and I can get rid of the sensor for the automatic setup. IDK if I need to get a knew wire harness for the inside of the car or what.
Let me Know
thanks
pm me
Old Nov 11, 2007 | 02:36 AM
Some people run the "P" wiring through the clutch pedal switch
as a safety device.
For backup lights, is there an unused electrical connector on
your trans?-Bob
Old Nov 12, 2007 | 05:57 AM
carobmor02's Avatar
Default lights
just used the reverse switch on the tranny and tap into your reverse light
relay and chip your ecu if you need any help pm me
