got a 95 accord with a srs lihgt on how to clear it?
if im right that means there is something wrong with the airbags?
But anyways there is a plug with 2 wires by the passenger floor board by the Ecu you have to run a wire between them (connecting both wires in the plug together)
then turn your key to accesory and the light should start flashing to tell you what is wrong.
google the error numbers and what not.
ok did some research.
its the Supplemental Restraint System (SRS)
The Honda Service Manual says:
1. Turn the ignition switch OFF, and wait for ten seconds.
2. Connect a short to the Memeory Erase Signal (MES) connector.
3. Turn the ignition switch ON (II).
4. The SRS indicator light comes on for about six seconds and then goes off. Remove the short from the MES connecotr within four seconds after the SRS indicator light went off.
5. The SRS indicaotr light comes on again. Reconnect the short to the MES connector within four seconds after the SRS indicator light comes on.
6. The SRS indicator light goes off. Remove the short from the MES connector within four seconds.
7. The SRS indicator light indicates that the memory is erased by blinking two times.
The ten second delay at the beginning is very important or the memory will not reset.
Try going to a honda dealer, I did that before because my srs light was on and they fixed mine for free. They might do that for you too
NOW Im SPRAYING
Dont Be A PUSSY Spray That SHIT!
www.ogrbreaks.com" target="_blank" rel="noopener noreferrer nofollow external">www.ogrbreaks.com
www.unitedbreaks.fm" target="_blank" rel="noopener noreferrer nofollow external">http://<span style="color:Blue">www....eaks.fm</span>
HUNGRY? DON'T GO AND HUNT FOR DEER JUST FUCKING HIT THEM WITH YOUR RIDE!
NOW Im SPRAYING
