problem Filling tranny with fluid
Old Oct 28, 2007 | 01:11 PM
DSMboost97's Avatar
How long will it last?
Default problem Filling tranny with fluid
Im helping a friend replacec the clutch on her del sol and when we got the tranny off, we drained all the old fluid out of it. Now that the clutch is replaced, we took out the speed sensor to fill the tranny with new fluid, and as we were poring the new fluid in, it started pouring out of the holes for the axles. Do the axles have to be in to fill it up with fluid? Is it normal? When we pulled the axles out and the tranny off, it never leaked out of the axle holes. Any ideas?
Old Oct 28, 2007 | 01:45 PM
mtber's Avatar
Install the tranny & axles, then fill the tranny.
Old Oct 28, 2007 | 05:45 PM
My Honda Is Slow's Avatar
No really,....it is
yes, the axles have to be in it for it to hold fluid. if you drained the old fluid before removing the axles, then thats the reason it didnt pour out.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Oct 28, 2007 | 10:53 PM
SmokinS13SR20's Avatar
That ginger...
That seems REALLY odd to me...
Whenever pulling axles in a buddy of mines honda (we worked on her alot) I've never had more then a few drops come out...
Old Oct 28, 2007 | 11:07 PM
custom240sx's Avatar
DC Crew Member #1
You can put the car on jack stands, fill untill the fluid starts to run out of the axles, install axles back in and reinstall tires, lower, done. The lowest part of where the axle sits in the tranny is flush with the actual filler hole on the tranny which means if it drains out the axles you are full anyway.
Old Oct 29, 2007 | 05:16 AM
rangcrx's Avatar
engine building &best
thats cause when you jack the car up it tilts to one said moving the fluid to the other side..but yes i would put the axles in first why would you not have put them in b4 the fluid where thinking about starting it without them in there
i love AUTOZONE
Old Oct 29, 2007 | 05:37 AM
weeper's Avatar
if u aint boosten go home
some funny shit homie i think you might want to stick to dsm lol and just for the record i think all front wheel drives need to have there axles installed before you super soak that hoe !
Like us on facebook
Old Oct 30, 2007 | 05:35 AM
DSMboost97's Avatar
No, i actually pulled out the axles, pulled off the tranny, carried it all over the place and it never once leaked out of the axles holes. So i was kinda concerned when it started pouring out just from adding some.
Thanks for the help guys.
Old Oct 30, 2007 | 05:37 AM
DSMboost97's Avatar
Trust me, I plan to.
Old Oct 30, 2007 | 12:25 PM
DC Crew Member #1
lol it prolly poured out when you added some because it didn't need anymore. put the axles in and (if b-series) pour in 2.5 quarts through the rubber cover thing (i think its like a breather or something) in the front of the tranny by the block.
