car keeps dieing
Old Oct 25, 2007 | 12:19 PM
hmongxiongkhov's Avatar
Default car keeps dieing
got a problem started about last weekend whenever i stop at a red light it just idles out or dies dont know whats wrong but it keeps happening so right now i have no car and the check engine lights on so help me if u can i have a 98 civic hatch with stock motor d16y7. thanks .
Old Oct 25, 2007 | 02:08 PM
EconoBox's Avatar
Four Door Mafia
Check the code.
Here is a tutorial if you don't know how:Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): The new CEL thread (includes how-to and codes)
Then reply and let us know what code so we can give you a much better answer as to why your car is not starting.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Oct 25, 2007 | 03:37 PM
chi town brat's Avatar
! Ne shab'rud'ni !
screw your idle air control valve screw all the way shut and see if the car dies out, if it does then you have a bad IACV because it should keep the car running when the airway is closed
if the car stays running turn back the screw 3 times to get a base of where it should be idling at. if you have it too far open your car will surge at a stop i.e. being stopped at a stop light.
def check the CEL code and let us know
Old Oct 25, 2007 | 05:25 PM
thanks.
Old Oct 25, 2007 | 05:31 PM
FC_V8's Avatar
Matt get a swap......... lance..
Old Oct 26, 2007 | 02:48 PM
Thatguysstuff's Avatar
Hey its that guy!!
Spark plugs?? wires?? Cap?? Rotor??
I had my 95 civic doing the same thing turns out had a shitty Msd Cap on the dizzy...
check those first.
