Questions concerning mpfi wiring.
yes but I can speak english...and all 4 injectors work perfectly fine on my dc teg paco. Maybe you should've invested your money in rosetta stone.......
those are power wires
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
I <3 WIRES
chipped P28's $125
????? Didn't know that. Are the colored wires grounds or positive too? Not trying ot be a dick jsut curious. But still in either case the obd1 injectors require 12 volts and the resister box puts them to 5.5± volts right? You know it better than I do, just trying to figure this stuff out too.
I <3 WIRES
chipped P28's $125
I <3 WIRES
chipped P28's $125
the injector box reduces the current(amps) not volts. The colored wires(brown, red, blue, yelow) that go to the ecu are "ground wires", the ecu contols the injectors by grounding them. DO NOT GROUND these to the body, or any wires that go to the ecu for that matter. -Neal
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
what is a 89 civic ek???
I thought 88-91 are Ef's?
But anyways if you are running OBD1 injectors you should put all of the wires that go to the resistor box and solder them together and remove the resistor box.
I was going to be running OBD1 injectors in my Rex but found some OBD injectors that you have to use the resistor box.
HAHA... Classic TR. I just want to see this 89 EK with DPFI!
