!!!!!oil on spark plugs!!!!!
Old Oct 10, 2007 | 12:10 PM
el b18's Avatar
$$ = boost :( = NA
Default !!!!!oil on spark plugs!!!!!
picked up a gsr swap for a friends crx, and the spark plug electrodes are soaked with oil. oil is slightly puddled at the bottom of the spark plug tube. plug wires and porcelin are clean and dry. all valve cover gaskets including spark plug seals and grommets are brand new. motor ran nice for a while now it wont start
Old Oct 10, 2007 | 12:11 PM
MilanoCivic97's Avatar
smooth as its name.
did you replace the spark plug seals with the valve cover gasket? they are known to go bad on hondas and usually come with the valve cover gasket kit.
Old Oct 10, 2007 | 12:13 PM
el b18's Avatar
$$ = boost :( = NA
yep. thanks though
Old Oct 10, 2007 | 12:22 PM
smooth as its name.
reading owns me. good luck man.
Old Oct 10, 2007 | 01:00 PM
KJ's Avatar
KJ
bored at work
If oil is in the spark plug tube it came from the top. Looks like the spark plug seals were installed wrong.
Old Oct 10, 2007 | 01:26 PM
el b18's Avatar
$$ = boost :( = NA
the nose of the spark plug is soaked with oil. and the motor doesnt start
Old Oct 10, 2007 | 01:28 PM
sleepinsol's Avatar
starting over
everything torqued down tight enough?
Old Oct 10, 2007 | 02:08 PM
DemonCivic's Avatar
do a cylinder leak down test. if the electrodes are oil soaked, you may have bad rings. g/l
Old Oct 10, 2007 | 03:11 PM
el b18's Avatar
$$ = boost :( = NA
yea wasnt lookin forward to the compression test
Old Oct 10, 2007 | 06:07 PM
My Honda Is Slow's Avatar
No really,....it is
compression tests are easy. should take all about 15 min and will tell you whats wrong with it.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
