Help with car stalling in the morning
Old Oct 5, 2007 | 05:31 AM
CBURKE's Avatar
Has to many projects
Question Help with car stalling in the morning
Seems every morning now when I start my car it's fine until I drive off. When I get to the stop sign at the end of the road it try's to stall. I rev it a few times then it's fine. Has anyone had this prob before?
1994 Civic
B16A
Do you thing the VAFC could have anything to do with it?
Or a dirty fuel filter? Cant remeber when I changed it but I know I did.
It used to pudder when I start it after it sitting for a few days not it does this every morning.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Oct 5, 2007 | 07:04 AM
nocomply540's Avatar
is retired...
Does it stop once the car is all warmed up??
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Oct 5, 2007 | 07:25 AM
CBURKE's Avatar
It's fine after I rev it a few times
Cburke.industries.
Old Oct 5, 2007 | 11:16 AM
DemonCivic's Avatar
any other symptoms? i.e. rpm hunting, check engine light, sticky throttle, change in rpms with a/c on or steering while stopped?
Old Oct 5, 2007 | 07:01 PM
is retired...
Try getting a new pcv valve and cleaning out the IACV and that other past right under the throttle body. I dunno If I say you put a new breather box on as well if not give that the once over. I'd use some break clean. Be sure not to srpay it on painted surfaces.( I learned the hard way)
Old Oct 6, 2007 | 05:32 PM
TurboedHondaB16a's Avatar
Thats what she said
I have the same problem with my b16 ef. You go to take off and it starts sputteringand it wont go nowhere. You rev it up and it stops. It makes me mad. I dont think its the fuel filter because i changed mine last week and its still doing it. If you find out what it is pm me and let me know so i can can do the same. thanks bro
Old Oct 6, 2007 | 07:57 PM
-campy-'s Avatar
could be water in the gas somtimes the cold weather causes the condensation and the slightest bit f water will do that
Old Oct 7, 2007 | 08:49 AM
Punkinterviews's Avatar
Chavez Motorsports
Mike, call me so we can get squared away on what you owe me. 813-546-9197
Sorry for stealing the post
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Oct 8, 2007 | 04:24 AM
CBURKE's Avatar
No none of the above. I did let the car sit a little longer so let the car start to heat up a little and it was fine. So I don't have a clue.
Cburke.industries.
Old Oct 8, 2007 | 07:56 AM
DemonCivic's Avatar
its obviously temp related. could be temp sending unit. i have seen them give the ecu the wrong values and cause cold start problems with no check engine light.
