LS/Vetec. I'm pretty ignorant when it comes to building someont like an LS/Vtec
i built mine like almost 2 yrs ago...all oem parts also...just do it right and spec everything out....i also used the golden eagle kit.....almost 40k on it now with no problems
n +1 on the golden eagle kit. comes with literelly EVERYTHING u need and directins too. made life that much easer come build time.
u used itr rods??? thought they were longer than ls and would cause problems??? myne are ls rods that are the strongest u can get b4 u go h beam..n they got the upgraded rod bolts too.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
The only advice have that I dont see listed commonly is dont use the p30 headgasket that golden eagle supply's you with. It will leak on the timing belt side, instead use an LS headgasket and have the dowel pin holes on the head gasket bored out to fit the ones for the head.
Ricky
Ricky
that kit is a waste of money.My 2cents i am useing a 24buck oil line special made/a autozone headgasket 30bucks ebay dowls.12bucks and .23cent plug for the head about 65bucks for everything and still 80kmiles and no its not luck i use the same thing on all my lsvtecbuilds : o )
i love AUTOZONE
i love AUTOZONE
GS-ARR
