Stock compression for a Civic
Old Feb 12, 2001 | 03:32 PM
civicextpa's Avatar
Does anyone knows what is the stock compression of a 93 civic?. I did the compression test and I got 205 psi with 138000 miles.
Jorge
Old Feb 12, 2001 | 05:17 PM
hybridEG's Avatar
iam not totally sure but i think its 9:2:1 but hay who am i
PWN3D SHOT TYPE R SAMPFAG AND MORE COMMENTS FOR SECRET SERVICES TO MAKE FUN OF SOON................
no turbono nitrousall rainforest
aim...rainforestEF8
Old Feb 12, 2001 | 05:18 PM
hybridEG's Avatar
shit i read the question wrong ill get back to you on that
aim...rainforestEF8
Old Feb 12, 2001 | 06:28 PM
Bill's Avatar
Livin' in Seattle
Usually when you do a compression test you do it across all cylinders. Your number 205 is it for all cylinders or did you just do one? Also 205 for any cylinder on a 93 civic seems kinda high.
Old Feb 12, 2001 | 08:57 PM
KJ's Avatar
KJ
bored at work
205 is very good compression. But what you want to do is check all four cylinders. Most likely they will all be a little different (+or- a few points). What you need to check for is whether one cylinder is significantly less than any of the others. If all cylinders check out to about 205 you are in very good shape especially with 138k miles.
Object in mirror are losing.
<FONT COLOR=#a8a8a8 SIZE=1 FACE=Verdana Arial>This message has been edited by KJ on 02-13-2001 at 12:58 AM</font>
Old Feb 12, 2001 | 09:14 PM
Bill's Avatar
Livin' in Seattle
205 is good yes but kinda high on a 93 civic. With 138k on oddometer though I guess the carbon build up has added in pushing the compression up a bit.
Hey KJ how are you enjoying your LS/Vtec?
Old Feb 12, 2001 | 09:17 PM
Bill's Avatar
Livin' in Seattle
youll also want to make sure the motor is hot. If you do a compression test while the motor is cold you will get abnormally high readings.
Old Feb 13, 2001 | 12:50 PM
KJ's Avatar
KJ
bored at work
Originally posted by "Someone"
I enjoy it quite a bit. Hell of alot better than the b16a I was running.
Old Feb 23, 2001 | 06:10 AM
civicextpa's Avatar
Thanks for all your input. I delay in reply becasue I could not find the paper that I have with the numbers for the compression test. This is how I did the test
The car was warm I took all four wires and did the test in all four cylinders. As a mater of fact I did two runs. These were the results.
1st try
200 207 205 200 avarage 203
2nd try
205 202 202 195 average 201
Also I found no oil around the spark plugs which I belives is indication that the rings are doing thier job.
As far as carbon built up I dont think I have a lot. I have done recently a complete induction system clean up(injectors etc) at a honda dealer. In additon they cleaned part of the throtle body.
Alos I notice that my car does not smoke at all (high/low rpm).
I personally belives the car is in good shape thanks to the help of mobil 1 and prolong.
Let me know your thoughs. Once again thanks for your input.
Jorge
Old Feb 23, 2001 | 06:35 AM
KJ's Avatar
KJ
bored at work
Those numbers look very good. Congradulations.
KJ
Objects in mirror are losing.
