Help with b16 ef
Old Sep 25, 2007 | 02:50 PM
silverhonda217's Avatar
Default Help with b16 ef
I just put a b16a1 in my 91 dx civic and every thing is hooked up into the ecu the injectors, knock sensor, vtec, and distributer. but it will not pass 3000 rpms. does any one know what this could be?
Old Sep 25, 2007 | 03:07 PM
sleepinsol's Avatar
starting over
is ur speed sensor working and does the ecu have a 2 step set? if the speedo reads 0 and u have a 2 step then thats where the rev limit will b. other than that ihave no idea y u cant go past 3k....
Old Sep 25, 2007 | 11:36 PM
custom240sx's Avatar
DC Crew Member #1
the ecu is in limp mode.
Old Sep 26, 2007 | 12:05 PM
nocomply540's Avatar
is retired...
The guy that I bought my car from had this same problem when putting my car together I'll give him a call in a bit. IIRC it was ignition wiring running to the gauge cluster.
EDIT: I just talked to him and it was the coil. He was having the same exact problem as you are.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Sep 26, 2007 | 03:19 PM
DC Crew Member #1
the coil shouldnt stop it from reving past 3k...I have seen 2 coils go bad and they either stop the car from running period or it will run fine.
Old Sep 26, 2007 | 03:27 PM
RexSiChic's Avatar
Nitrous Queen
Sure you already checked this, but my Crx did this. After replacing the plug wires & dizzy we found one of the old ones was missing the metal piece on the end.
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
Old Sep 26, 2007 | 08:31 PM
sillywhips's Avatar
i have had this happen and all it was when i wired up the distributer from dual point to multi point i had the white wires backwards i switched them and then it was fine try that
shared_pm me if you need any honda swap or repairs done or welding done. in car engine rebuilds in a day like a boss
Originally Posted by rangcrx
trust me the girls like it black
