Engine Hesitation
Old Feb 4, 2001 | 10:48 AM
VDormCRX's Avatar
I have got an JDM B16A with the two O2 sensors on the Manifold. I have been told it is a common problem with swaps of this type. During the process of driving at a constant speed the car hesitates but it is not stuttering. Now it clears up when the gas pedle is depresed but then comes right back. And now it is starting to do it on acceleration too. I need help on this. And I need to know what to buy or do to correct this because it is very annoying. Thanks.
Old Feb 4, 2001 | 03:49 PM
RicerX's Avatar
Icy Hot Stuntin
Hey
Sorry I dont really have a solution to your problem but I thought id let you know your not the only one. I have a B16a1 im not sure if I have two O2 sensors also but it does the same thing when I hit a certain throttle percentage. When I put my foot on the gas about 2/3 of the way down my car starts to hesitate a little. So I pretty much have to either floor it or go a constant speed. I cant gradually accelerate. I think its probably a dirty fuel filter or dirty/clogged fuel injectors but i havnt gotten a chance to check/change them.
Hope someone has some sort of insight to this.
Mike.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old Feb 4, 2001 | 06:09 PM
X CVC's Avatar
Bad primary O2 sensor?? mine had the same problem it hesitate everytime i gradually accelarate as it hesitate my air/fuel ratio lean out so now that i bought a new one (250 wtf?) its all good as new !
Old Feb 4, 2001 | 06:48 PM
Bill's Avatar
Livin' in Seattle
before you go spend the money on a new sensor bust out the ol multimeter and check the i/o and signal voltages. Not sure what they are off the top of my head but Im sure if you private message John or look on the hybrid board youll come across them.
Old Feb 4, 2001 | 08:21 PM
Bill's Avatar
Livin' in Seattle
VDorm - I had this problem in my 88 DX B16a. I changed O2 sensors (both) injectors fuel filters ECUs throttle bodies every sensor I could find and no luck. The only things I never did was change the injector resistor box and try adjusting the TPS. I know of other B16a CRXs that have had the same problem and no one can figure it out. I cant tell you how many bracket races I lost due to that problem.
John
<A HREF=http://www.vapor-trail.net/mydyno.html TARGET=_blank></A>
Need some time on the rollers? Click Here
Old Feb 6, 2001 | 11:28 AM
KJ's Avatar
KJ
bored at work
Try swapping the o2 sensors with each other. (i.e) change their places. Ive seen this correct the very same problem give it a try.
P.B.Y.M.
Old Feb 7, 2001 | 06:24 AM
VDormCRX's Avatar
Thanks for all the input. By the way do you know anyone who might be interested in a B16B or anything from the front clip of an CTR. Get back to me soon.....
