Camber Correction
Originally posted by "Someone"
Originally posted by Bill:
Yes camber will promote some inside wear on the tire BUT its the toe that causes the excessive wear. Go get an alignment done. Toe can be changed using alignment gauges but Id recommend just taking it to an alignment shop. Toe is the direction that your tires point if you were to think of them as a vertical plane along the y-axis and its neg/pos values being in relation to the z-axis with x-axix representing 0.
THE DRAGON NEXUS
Professional Pee Pee Puller
There shouldnt be any rubbing if people would just install tires of the right size and of the right offset in relation to their drop.
No more Zex for me! Only Venom!
http://www.geocities.com/markaccord95
www.superhonda.com/projects/accordproject
http://www.floridaracing.org
Originally posted by marksaccord95:
actually they all were
a little negative camber never hurt anyone its the toe that will eat up tires quicker than shit.
