need new suspension set up any ideas???
Old Dec 16, 2000 | 07:03 PM
cornishcrx's Avatar
gamehen
i have ground controls with tokico adjustables on my eg hatch right now and the ride is really rough on my daily trip to work everyday. has anyone used suspension techniques with stock springs? any help would be great! -john
1992 Civic stock k20 w/boost: 10.69@133 sold
NS Racing
Old Dec 16, 2000 | 08:42 PM
Tron from da Ci-tay's Avatar
Look At Me America
Loosen up your Tokicos. What spring rates are your ground controls????
ROCKY
TEG Widower
Hatch Builder
**see the back of that hatch??? get used to it
ONE LUV
Old Dec 16, 2000 | 08:45 PM
Look At Me America
I have several options for you varying in price.
A) Raise your car UP. This is the most common cause of crappy rides in cars with coilovers. Too little suspension travel causes you to bottom out which can give you a very bad ride.
B) Play with the compression and rebound settings on the Tokicos. Could easily solve your problem in conjunction with solution A
C) Order softer springs from Ground Control. The softer spring rate could solve your problem.
D) Replace the Tokicos with Koni shock absorbers. I have many satisfied customers with Konis and used them many times in my own personal cars.
E) Try a full threaded body coilover like the ones from Apex-i. I just installed these on my Civic and I am very impressed with the ride quality. Not the absolute greatest for handling (at least for me Im very demanding) or racing but a great street coilover. They retail for 1200.00 but street prices are a little lower than that.
One of these options is bound to solve your problems. Good luck.
John
Tampa Racing Moderator of For Sale Local Scene News and Honda/Acura Tech forums.
vapor.trail@gte.net
Those with golf balls golf.
Those with real balls race.
All about me. Everything youve never wanted to know...
ONE LUV
Old Dec 18, 2000 | 06:32 AM
Bill's Avatar
Livin' in Seattle
How low is your drop?
Im betting that when you dropped your ride you did it pretty low and didnt bother to get to reset the suspension components (a good alignment shop can do this for you). You may have ripped some bushings. With adjustable shocks you shouldnt have a problem a rough ride since you can control spring oscillation.
Old Dec 19, 2000 | 12:54 PM
marksaccord95's Avatar
TR Registered Member #5
Koni adj and neuspeed race i love my combo
No more Zex for me! Only Venom!
http://www.geocities.com/markaccord95
www.superhonda.com/projects/accordproject
http://www.floridaracing.org
Old Dec 19, 2000 | 04:05 PM
low4cyl's Avatar
Hello new to the board.
In any case I use to have the Konis on my car with an H&R springs> I dint really like the way the Konis were put together and they made alot of noise especially in the right rear. Now I have H&R coilovers they cost a pretty penny but the ride is 100% better and I love the way they handle.Took me like 7 months to get them though cause alot of the sets are are spoken for for racing use.
Old Dec 23, 2000 | 03:36 PM
x3madness's Avatar
i have tokico adj and eibach pro kit which only lower my eg 1 the ride is just as good as stock
Old Jan 7, 2001 | 08:17 AM
KS_JDM's Avatar
Like QuickF20c said; A full threaded coilver system will provide the best ride quality and overall adjustability for the money.
Is is right most of these systems will cost a pretty penny but you will be getting height and dampening control with most of them. Assuming you have a Honda there are bunch of companies that offer those systems. I have the Apexi N1 Dampers which offers 13 way damping and ride height adjustability but you can get the WS series for a much lower price. Unless you find a deal.. I got mines for $750.00 the owner(my cousing) had them for a month only. Here are other companies to consider.
TEIN
H&R
Neuspeed
and theres lot more to search around
just trying to contribue
Old Jan 7, 2001 | 05:14 PM
Bill's Avatar
Livin' in Seattle
Are you sure you put them on right? Ive got Koni Yellows with H&R sport springs and Ive got no noise at all. I am however not too fond of the way the spring perch is held (just a basic clip) but other than that Im extremely satisfied with the setup.
