BEST DIRECT SWAP
for a 89-91 civic or crx what is the biggest and best engine swap? b18c? curious what your opinions are...thanks
The glass is neither 1/2 full or empty. It simply contains 50%of its total capacity.
best direct bolt on swap is the 1.6L DOHC ZC engine its a complete bolt on it will even bolt to your stock tranny and you can get the engine for about $395-450...its got 130hp perfect engine to go with a small turbo.
the next one I suggest is the 1st gen B16A its not a bolt on you need to custom make your mounts or buy them from Hasport place racing...etc
some people have had hood clearance problems so I suggest you use the ZC hood it gives a little bit more clearance. The next would be the B18B/A then the B18C1/5 and finally the H22A which I completely not recommend anyone to do this swap unless you like big headaches and spending extra cash...take care
ME LIKES TWISTIES!!!
Incògnito
Incògnito
i have helped with a zc swap and even though it being a pain in the ass it was a direct swap and makes his crx move pretty damn good best way is to keep the crx si tranny and just re-do a few wires and thats it your in like flin.
teal 94 integra gsr 99 saw blades aem intake &cam gears. moderating since sep. 2000
skunk 2 coilovers
skunk 2 coilovers
Incògnito
Incògnito
isnt there a stroker kit for the b16 and also for the b18? wonder if that with some wild cams would give me some good #s. is there any way to get low end grunt out of the b16 or b18 N/A without losing too much top end?
which is more cost effective and bang for the buck-turbo or jrsc?
well if you want to put a b18c in the crx and supercharge it then you should talk to john wilson at LHT performance (727)344-1800 he had one in his crx for a while and that thing hauled serious ass he can also help with the advise about the b16a also he does these swaps and can get you any motor you want
skunk 2 coilovers
skunk 2 coilovers
Well if you want the ability to make serious power your BEST choice would be a B18C. Remember there is no replacement for displacement so why go with a 1.6 if you can go with a 1.8 I beliee the only thing you need is a mount kit. Try HASPORT Give John at Spec-R a call (910-7235) He can tell you all the specifics... and may be able to track a swap down for you.
ROCKY
TEG Widower
Hatch Builder
ROCKY
TEG Widower
Hatch Builder
ONE LUV
ONE LUV
