Clutch Question
Old Sep 19, 2007 | 06:03 PM
LATINO HONDA's Avatar
BALLER
Default Clutch Question
I Am Putting A Ls In Mt Rex Was Wondering If I Would Have To Change My Clutch Cable Cause I Just Cant Fit It On There So I Also Put A Stage 3 Clutch If That Matters The Inside Metal Line Isnt Long Enough Or Something Please Need Your Info
Old Sep 20, 2007 | 11:40 AM
emoboy44's Avatar
I put an LS in mine and i used the stock crx one..well mine was automatic..but i converted and baught the civic clutch cable form discount and it worked perfect. It shouldn't matter what clutch you are using.The clutch line shouldn't need to stretch. I would try raising the clutch fork up and sliding it on. Then put it down and see how much play you have.. Also i see alot of people try to put it under the intake manifold..Make sure you run it over the motor with the LS or it wont reach.
Old Sep 21, 2007 | 04:50 PM
BALLER
i cant even pick the fork clutch up
Old Oct 3, 2007 | 09:11 AM
BALLER
