putting a y7 block on a z6 head? help
Old Sep 17, 2007 | 10:37 AM
deerhunter21's Avatar
Default putting a y7 block on a z6 head? help
hi i have a 1994 honda civic i race circle track i have blown 2 motors z6.can i use a y7 block and just put my z6 head on it.if so which head gasket do i use.i usally run 2nd gear on the track and wind it pretty tight any help would be appericated i need to win....thanks
Old Sep 17, 2007 | 11:03 AM
Hater's Avatar
Free base cocaine
eh, you'd use the z6 gasket, but how do you plan to put a block on a head? jfwy, any way yeah that would work out pretty well those are the proper "mini me's" btw search honda tech theres a ton of info on them.
Old Sep 17, 2007 | 01:40 PM
so they are both 1.6 just swap the z6 block to the newer d16y7 block.will it run just like the z6.thanks again
Old Sep 17, 2007 | 02:10 PM
Derka's Avatar
TR Balla Donor Supreme
you might need a different timing belt, im not sure though. You might need the z6 or y7 but im not sure which one.
1998 crv daily beater
Old Sep 17, 2007 | 03:52 PM
ekhatchboy's Avatar
Redrocket part 2
just use the original cam gear and he wont have to swap belts. but either way i believe they are the same.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Sep 17, 2007 | 05:26 PM
thank yall very much
Old Sep 18, 2007 | 08:05 AM
BLK94EGCOUPE's Avatar
some nissan
This isnt true the cam gear doesnt make the difference the actual height of the head or the thickness makes the difference like I know for the D15B7 Z6 combo the belt need to be changed
Old Sep 16, 2011 | 10:25 AM
jdmricardo's Avatar
[JdmEghastck813]
i did for swap my homeboy z6 head on y7 block and there not differen cam gear same and u can use ur old y7 belt and u need z6 one 140mm studs on corner near vtec sol and use y7 all bolts studs 120mm...
[ RICARDO_DYNO BOOST]
