Over heating Problem...need advice..
my car is overheating and i took it to a shop already and they tried a couple things and couldn't fix it. my brother says maybe water pump..but i would appreciate any advice or input you could give me.
The shop replaced 2 temp sensors and radiator fan module, repaired wiring under battery so fans will run only in on position. coolant fan switch, cooling temp switch, coolng fan module. Thermostat and Gasket as well. but it didn't fix the problem.
What else could it be?
honda water pumps like to makea really loud howling noise when they stop workning, that is unless it sezies which i doubt, try running your car and listen to the right side of the engine. and +1 to see if the weepers leaking.
