valve adjustment
Old Sep 15, 2007 | 02:40 PM
thundermax's Avatar
blown
Default valve adjustment
I think that my valves need adjustment, there is a ticking-knocking sound around 1500 rpm. I've been told that I need a valve lash adjustment. Now my question is Would I be able to do this myself or should I take it somewhere to get it done? And is there any writeups on this? my car is H23 prelude
Old Sep 15, 2007 | 02:48 PM
Gixxer's Avatar
Hide your daughters
It's easy (with the right tool).
Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
Old Sep 15, 2007 | 03:16 PM
nolexforever's Avatar
yup, with the right tool its a piece of cake. i bought the snap-on tool for $70 and its worth every penny. i did the valve lash adjustment done in less than hr on my first try.
Old Sep 15, 2007 | 04:30 PM
thundermax's Avatar
blown
Is this procedure the same for my H23? thanks
Old Sep 16, 2007 | 01:58 AM
sxecrow's Avatar
EG2 CRX
The procedure is the same w/ any VTEC engine. Just be sure to use the correct measurement. I'm unsure if the h23 is the same as the b series: .006-.007" and .007-.008"
Old Sep 16, 2007 | 04:47 PM
thundermax's Avatar
blown
does anyone have the correct measurement for the h23?
Old Sep 16, 2007 | 05:16 PM
custom240sx's Avatar
DC Crew Member #1
Listen to you injectors first on idle and see if that is where your noise is coming from...I was about to bring my ls to get everything adjusted on the top end until my buddy told me to listen and see if it was actually te injectors making the ticking sounds and it sure enough was...I mean adjusting the top end is deff. a good idea but check that too cause that may be the only noise your hearing.
Old Sep 16, 2007 | 05:28 PM
thundermax's Avatar
blown
It's definatelly not the injectors, I can hear them tick, but the sound that I'm getting is coming from the valvetrain.
