another turbo question
save the s.o.h.c
on
ok heres the deal. i got a y8/ turbo. the deal is it wont build boost. its not the couplers or pipes its deff the turbo itself. it spins fins and has little play. but when i get on it it starts to build boost then drops off. stop w/ the car at idle i look and its not spinning. snap the throttle real quick it spins. w/ the car off its not seized up or anything. its a t3/t4 to4h i believe. i am running a restrictor w/ a 3 an line. could that be the problem. i was told to always run a restrictor even w/ a 3an due to honda high oil pressure. but now i see some saying its not need w/ a 3an. thanks
I wouldn't expect a y8 to spin a t3/t4 at idle so don't blame the turbo based off of that. I personally would not run a -3 with a restrictor but I'm not going to say that is your problem. How are you sure you are not leaking at the couplers or welds of your pipes, have you leak tested it?
save the s.o.h.c
on
havent leak tested it but it built boost once and stopped since. it make a loud sewing machine sound. was told it might be out of balance. there are no obvious leaks i would think if there was any small leaks i would build some kind of boost.
Is the turbo new?
Who manufactured the turbo? Boost leak test before you say you have no leaks. A lot of people say that and I usually find at least one. Take the restrictor off the -3 line
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
save the s.o.h.c
on
^^^^ went little further, just took it off. noticable contact of the blades to housing. just some light scuffing tho. didnt damage fins. so imma say time to swap it out go na for now. plan on buying a new garrett 42/48
PS, Non ball bearing turbo's = No restrictor as long as you are under a 6an line, ANY Ball Bearing turbo = restrictor.. journal bearing turbos can handle the extra psi without a fuss, BB cannot..
High bread race cars producing over 120PSI running journal bearing turbos rarly run oil restrictors and never have a turbo fail do to oil high pressure.
In almost 95% of the cases we get turbo's back for rebuilds and are told the seals are gone, turn out to be the case of faulty oil return lines. Either the lines are to small or are not installed correctly.... only a select handful of them actually have seal issues due to high oil pressure..
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
had a similar situation on an LS kid took off his WG and when he put it back on forgot to install the ring that goes underneath it and this caused him to not really build boost. lmk if that helps any.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
save the s.o.h.c
on
took the turbo off and could see where the wheel was hitting the exhaust housing. not really hard but im sure it was effecting it. the turbo made a howling sound and i was told it was due to it being out of balance.
