wiring issues
Old Sep 14, 2007 | 11:45 AM
LShatch98's Avatar
i love making you mad <3
Default wiring issues
ok well i need help. im not getting any spark. i change the dizzy,wires,plugs,starter. and noting. changed the harness. i have a 98 civic hatch with an ls swap. obd2a with a obd1 ecu n jumper. and im not getting spark.
Proven Power for all your go fast needs
Old Sep 14, 2007 | 11:56 AM
emoboy44's Avatar
u change the whole distributor.. or just part of it?
Old Sep 14, 2007 | 12:01 PM
LShatch98's Avatar
the whole thing.
custom240sx's Avatar
DC Crew Member #1
ignitor possibly...thats what I have seen go in MANY dizzys that will stop the spark.
Old Sep 15, 2007 | 09:09 PM
LShatch98's Avatar
Old Sep 15, 2007 | 09:45 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Check with a voltometer/multimeter for power in all those harnesses.
Then go from there.
-Winston Churchill
Old Sep 15, 2007 | 10:45 PM
DC Crew Member #1
bro you can ohm the ignitor to see if it is bad...there was only one time ohming it didn't help and that was because there was something loose in mine that would sometimes ohm and sometimes not so I just replaced it anyway and problem was solved. Test it first cause those parts are $70 from advance auto...if the problem DOES lie in the distributor then 9 times out of 10 it is the ignitor.
