ecu question
i have a pr4 ecu people tell me it obd0 but i put it in my eg (obd1) and it worked fine. im putting a ls in a ef with a blown b16 will a pr3 run a ls or do i need to run the pr4 ?
your pr3 will run the ls i think you will get some codes but nothing to hurt you,i no the vtec code you will also get a code 20 for elict fault i think,i cant remeber what codes i got when i swaped mine but your pr4 im sure is from a 92 93 integra here the picture
obd2b
obd2
obd1
oreobd
Shot at 2007-09-14
obd2b
obd2
obd1
oreobd
Shot at 2007-09-14
i love AUTOZONE
i love AUTOZONE
Is the ls that your putting in the EF obd-1 ?
If the LS is obd-0 then get a pr4 that is obd-0. You always need to get the ECU that is made for the engine that you plan on running, unless it is custom.
glad it all worked out for you im sure you can make somethingto get another bolt on
i love AUTOZONE
i love AUTOZONE
