check engine light need help
Old Sep 9, 2007 | 06:33 AM
crazybus21's Avatar
Default check engine light need help
i have a check engine light on on my 94 civic how do get it to flash me a code.then how do i find out what the code is .thanks randy
Old Sep 9, 2007 | 06:40 AM
custom240sx's Avatar
DC Crew Member #1
I'm fairly certain that you jump the service connector thats by the passenger kick panel and then put the key to acc. and the check engine light will flash telling you what code...long flash is 10 short flashes are 1 so one long flash followed quickly by 4 short flashes is code 14.
Old Sep 9, 2007 | 08:08 AM
Gixxer's Avatar
Hide your daughters
Yep, and if the OP doesn't know what "jump" means, it's just completing the circuit, so use a paperclip or a small wire to connect the pins in the plug.
Old Sep 9, 2007 | 09:29 AM
crazybus21's Avatar
is the service connector just a 2 pin plug that i run a wire from one to the other then watch the check engine light?
Old Sep 9, 2007 | 10:28 AM
TSX24L's Avatar
yes, make sure the ing.switch is atleast turned on. DOn't have to start the car. Just watch it while you have service connector jumped.
