Auto to manual swap on 92 DA Teg
Old Sep 5, 2007 | 06:24 PM
hkshaitian's Avatar
true dat.
Old Sep 5, 2007 | 07:12 PM
rangcrx's Avatar
engine building &best
YOU cant use a auto Ecu in a manuel Car you will need a pr4 or pm6 5speed Ecu..the hardest part of this whole change over is the pedals...BUT also make sure you get some 5speed FLywheel bolts auto bolts are about 2mm shorter i would never chance it
i love AUTOZONE
Old Sep 5, 2007 | 07:55 PM
hkshaitian's Avatar
i knew there might be sumthin wrong with havin an auto ecu it sounds strange never heard of it done b4. the pedals are the hardest part 4 real? i was ganna wire up the clutch pedal so that the car wont start as an auto car
by the way this is haitianef9 i forgot that i waz signed into my brothers account
Old Sep 5, 2007 | 08:00 PM
rangcrx's Avatar
yes i dont know what he is saying custom240sx cause It will not work the ecu has what is called lockup Solenoid AND the ecu wil shut down when this code comes on i think its like code 19 and 29 or 30..padels are only hard cause hard to get to unless you remove th steeringshaft....but on a da/crx the change over is easy
i love AUTOZONE
Old Sep 6, 2007 | 06:56 PM
HaitianEF9's Avatar
EJ1
how much work is taking the column off i dun wanna go thru dat much...o nvm yes i do lol
Old Sep 6, 2007 | 07:15 PM
rangcrx's Avatar
2 12mm bolts 1 10mm and the wireing
i love AUTOZONE
Old Sep 6, 2007 | 07:23 PM
  #17 (permalink)
HaitianEF9's Avatar
EJ1
thanx the park reverse drive nutral drive and all the auto gears do i solder all those wires together?
Old Sep 6, 2007 | 07:30 PM
  #18 (permalink)
rangcrx's Avatar
no just the park wire just splice it and twist then wrap it if no wrap then use nice elt.Tape
i love AUTOZONE
Old Sep 7, 2007 | 08:39 AM
  #19 (permalink)
HaitianEF9's Avatar
EJ1
k thankz do i need to change axles? im guessing so
Old Sep 7, 2007 | 08:47 AM
  #20 (permalink)
rangcrx's Avatar
NO all axels are the same you will need to change MidShaft.unless you re size the bolts to move it down a bit
i love AUTOZONE
