Will ls rods fit in a b20 crankshaft??
Old Sep 4, 2007 | 04:00 PM
BABILLARACING's Avatar
Default Will ls rods fit in a b20 crankshaft??
Just curious....lmk...thanks....Omar
Old Sep 4, 2007 | 04:01 PM
EGKID's Avatar
Yup they're the same exact cranckshaft
Ricky
Old Sep 4, 2007 | 04:11 PM
sleepinsol's Avatar
starting over
yessir.....only difference between b20 and ls bottom end is the pistons. b20 are 84mm n ls are 81mm.
Old Sep 4, 2007 | 04:22 PM
the reason I ask is cause a guy on ebay is selling pauter rods and in the specs they are way different
pin diameter b20 .866 ls .827 gsr .827
be bore b20 2.008 ls 1.890 gsr 1.890
length b20 5.571 ls 5.394 gsr 5.430
be width b20 .935 ls .935 gsr .858
lmk what you think the guy specs are wrong or what??????
I don't want to buy the wrong rods.......
Old Sep 4, 2007 | 07:22 PM
sleepinsol's Avatar
starting over
if your going to buy aftermarket rods just get em for the block ur usin. they should all b the same, but some companies make them different bc the oem pistons are different. for example, i had to get my ls rods thinned out at the small end for my itr pistons to work.
just get the rods for the right block n u shouldnt have problems.
Old Sep 4, 2007 | 07:47 PM
rangcrx's Avatar
engine building &best
thats strang how the wrist pin dia. is so large cause all the bseries dia are the same...hmmm i dont know thats kindda iffffy unless they are custom..cause he has that the rod is almost 2mm longer from ls and b20....thats not true but all the other numbers are right
i love AUTOZONE
Old Sep 4, 2007 | 07:51 PM
sleepinsol's Avatar
starting over
mite b for a different crank......
Old Sep 5, 2007 | 04:30 PM
EGKID's Avatar
I wouldn't buy from ebay, just for piece of mind. Theres a possibility that they're fake.
Ricky
Old Sep 5, 2007 | 04:38 PM
rangcrx's Avatar
this is true..thinking about it why the hell do you need X-beams anyway h-beams will work fine for any build you are doing and eagle run about 280-310$ and buy the ones you need ls should have a model of 5394 in it for the rod size....and DONT BUY PROBE OR SCAT
i love AUTOZONE
Old Sep 6, 2007 | 12:23 PM
they might be overkill but this is what I am building
b20 erl sleeved block
wiseco 84 mm pistons
crower or pauter rods
gsr head ferrrea ss valves ,supertech dual valve springs and titanium retainers
bbk intake manifold bbk 70 mm tb
precision intercooler
turbo don't know yet gt35r or gt 42
tial blow off
tial 60 mm wastegate
1600 cc precision injectors (hold and peak)
gsr tranny with obx lsd and ls final gear drive
el gato tubular manifold
el gato fuel rail
this is some specs on my buil up .lmk....thanks.....Omar
