Fucking overheating hondas!
I got a 96 prelude and been having overheating issues,im loseing rad fluid,someware,it has a new rad,cap,and hoses,i got to put water in it every day,when it gets low on fluid,it comes out from someware i cant see ware from,any idea?
1996 Prelude
2004 GSXR 600
1996 Prelude
2004 GSXR 600
You have to find your leak first.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Check your hoses and tighten the clamps down.
-Winston Churchill
-Winston Churchill
I checked the head gasket and its fine(And over tighten one of the bolts and it snapped off,fuck I need a new 1.)WTF is wrong with this POS?Fucking Hondas',I always thought they were reliable!I always owned toyota!Now I remember why.
1996 Prelude
2004 GSXR 600
1996 Prelude
2004 GSXR 600
Actually I bet the thermostat didn't seal completely when someone put a new one in...either that or they broke off one of the I believe 10mm bolts on there allowing it to leak at pressure. The therm housing is connected to the other end of the lower rad house.
I had that problem once.... i cracked my radiator and didnt know it so about a week or so i kept having to add water. so then the crack got worse and i noticed it. so i changed the radiator, samco hoses, thermostat housing, and thermostat( it was sticking and thats how my radiator cracked)... so when i put the new thermostat in the gasket didnt sit right and for weeks i kept losing water so i had to take it back off which is the biggest pain in the ass, and i put high temp sealent and put it on right.. and havent had a problem since... you might want to check all your sensors, radiator fan switch, anything that could be causing it to over heat
