Valve seals??
K, the car smokes blue, at idle it puffs a little out, and at WOT it's a little worse..
I'm thinking its the valve seals but I'm not sure, is there any other ways to tell?
BTW - it's a GSR with CTR pistons, if that matters..
2011 Kia Optima SX Premium/Touring package
Check plugs, for oil on the bottom?
Also, say I run a compression test, the motor should be at 275psi or so, if it's the valve seals it wouldn't affect the compression?
It could be a chance that you have fried rings. Are all 4 plugs soaked in oil? Compression test should also be performed with WOT.
1990 Honda CRX Si - Sold to sprayedtegra
1985 & 1986 Suzuki Quadracer 250R's - Projects
1994 Jeep Cherokee - Daily Driver
I'm gonna run a compression test one day after work to see, but if the compression is good across all 4, it's the valve seals, correct?
Please elaborate on what you mean by performing a compression test with WOT? Are you saying that a compression test should be performed at Wide Open Throttle?? I would hope not seeing as this is impossible. Weak...bad valve seals would cause a loss of compression. Does the car missfire at all??
later
matt
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
gotcha...I don't see how this is going to alter the output of the compression test though.
