Recharging A/c..??...
Old Aug 16, 2007 | 05:57 PM
FC_V8's Avatar
Default Recharging A/c..??...
Hi guys.. well my moms 97 Accord a/c wasent feeling as cold as before so i went ahead and bought 2 cans of a/c Freon.. Followed instructions and now the a/c became worse.. sometimes its cold for 2-3mins.. then its gets warm, back and forth..? i dont know why its doing it.. Help appricated.. thanks
Also checked a/c belt, its on good..
Old Aug 16, 2007 | 06:45 PM
Steve C.'s Avatar
hoollaa
possible bad compressor?
Old Aug 16, 2007 | 06:51 PM
DatBoiNda813's Avatar
i wanna know too... cuz my civic does the same thing
Old Aug 16, 2007 | 07:22 PM
rangcrx's Avatar
engine building &best
YOU DID DO THE REFILL thru the LOWpressure side correct?if so what psi is your system at now?
i love AUTOZONE
Old Aug 16, 2007 | 08:10 PM
FC_V8's Avatar
Yes.. its through the L(low) pressure side.. not sure what the psi is at dont have a gauge..
Old Aug 17, 2007 | 08:21 AM
FC_V8's Avatar
ttttt
Old Aug 17, 2007 | 07:55 PM
Grizzly0205's Avatar
**BoTtLeS aRe 4 BaBiEs**
take it to any a/c shop and they will test it for you for free and let you know what the problem is, you can usually tell by what the psi is at on the high n low side. o yea they will try n get you to let them fix it...
Old Aug 18, 2007 | 08:45 PM
izzyaccord's Avatar
hey man check the ac relay it could be going bad
Old Aug 19, 2007 | 07:03 AM
dippincrx's Avatar
save the s.o.h.c
how many onces did you put in? how much does the system hold? does it have any signs of leaking anywhere? perhaps it is now overcharged. cans are a horrible way of charging. for one you need to pull a vac down before charging a system. id say have it done by a shop.
