A/c Helpp
Old Aug 4, 2007 | 08:27 PM
LShatch98's Avatar
i love making you mad <3
Exclamation A/c Helpp
I have 98 ek hatch CX that has no a/c and i want to put a.c in it. the car didnt come with ac from the factory. so my question is. is my car wired for a/c. thanks bc having no a.c sucks balls
Proven Power for all your go fast needs
Old Aug 4, 2007 | 09:43 PM
Look at the dash, if it has controls for ac, it will say so on the defroster/heating/cooling panel.
The wiring may still exist in the harness under the dash, even though it doesn't have the "a/c" dash panel.
Post a closeup pic of the dash control panel, if you will.
A/C can also be wired in to work, but simply, and under driver control
instead of "climate" control.-Bob
Old Aug 4, 2007 | 11:30 PM
CEMAYHALL's Avatar
www.CEMayhall.com
It will have everything under the dash but it will most likely lack the engine harness... Check for the harness in the engine bay! It will run under the radiator support (by the hood latch!)
Old Aug 4, 2007 | 11:34 PM
1BADP71's Avatar
E & I Certified
true. chances are you need an underhood harness . its seperate from the main harness and contains a couple relays as well . go to ace's and pick everything out from under the hood, then drop the glove box out and take the center section of duct work out . its simple , you dont have to remove the dash to get it out ! that center section contains a coil you need, you can also nab the firewall grommet at this time .
Old Aug 5, 2007 | 07:28 AM
LShatch98's Avatar
i have everything from my bros car. his came with a/c. so if i transfer everything from his to mine it should work.right?
Old Aug 5, 2007 | 07:36 AM
1BADP71's Avatar
E & I Certified
yes
Old Aug 5, 2007 | 08:20 PM
I would carefully note where each color of wire came from
on the back of the control, so you will know what wire on YOUR car goes where.-Bob
Old Aug 5, 2007 | 09:22 PM
LShatch98's Avatar
man this is harder than i thought.
Old Aug 11, 2007 | 06:17 AM
cxcivic's Avatar
swapin' Hondas since '95
its plug-n-play as long as you didnt cut anything
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
