Crx hatch leak....anyone else?
Old Aug 2, 2007 | 10:17 AM
RexSiChic's Avatar
Nitrous Queen
Default Crx hatch leak....anyone else?
Im sure it did it before, but ever since I gutted the entire rear of my Crx it leaks and leaves a nice puddle in the spare tire well. it seems to be coming from several different places but Im not sure exactly where, just the general area. Anyone else have this problem? Mine's a 91.
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
Old Aug 2, 2007 | 10:34 AM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
oh yeah.....mine used to leak from where the hatch struts bolt to.....it was coming from the top of the car where the seam sealer had broken down over time.....lift the hatch up, and where it gets bolted to the body, look in that general area and look for any obvious/apparent cracks in it...hope that helps......also could be taillights gaskets, quarter window seals..etc....... but i would start with top of car and work my way down....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Aug 2, 2007 | 10:36 AM
97HATCHY's Avatar
i had a 91 and it was gutted and leaked like hell so i drilled 3 holes in the back to let it all drain out
Old Aug 2, 2007 | 10:52 AM
CEMAYHALL's Avatar
www.CEMayhall.com
Also, poor water down the sunroof... There are tubes that drain the rain/ water out! It is common for them to clog with dirt and debris... If clogged, the water will drain down the pillar and into your
hatch Just another thought!
-Chris
Old Aug 2, 2007 | 11:34 AM
jojo69's Avatar
don't mind if i jump in ont he topic.
Got 92 Dx/Hatch and smae problem. switched out oem and put in used jdm lights, and with all this rain, same problem... leaks in... I use the "squeeze an old rag to soak up the water and dump it out and u remember too (if u forget, i'll start to smell! lol)
defintely getting annoying!
Old Aug 2, 2007 | 01:45 PM
HondaHouse's Avatar
-Chris
+1 yeah i forgot to mention that one....i even had that problem
Old Aug 2, 2007 | 03:06 PM
RexSiChic's Avatar
Nitrous Queen
Thanks for all the input guys
~*~Ellie~*~
