Compression Question ?
Old Jul 30, 2007 | 04:28 PM
CRX-Si-Guy's Avatar
M-M-A
Exclamation Compression Question ?
What is the stock compression on a D16A6? If anyone knows, let me know. Thanks TR.
1990 Honda CRX Si - Sold to sprayedtegra
1985 & 1986 Suzuki Quadracer 250R's - Projects
1994 Jeep Cherokee - Daily Driver
Old Jul 30, 2007 | 04:32 PM
hondachris1994's Avatar
hatchback1994
just takin a guess i would say 160
Old Jul 30, 2007 | 04:47 PM
CRX-Si-Guy's Avatar
M-M-A
Your guess might be right, but i need textbook answers. I need to know what compression should be coming up when i do a compression test.
Old Jul 30, 2007 | 05:14 PM
Hybrid_eg's Avatar
i like the blue ones
Normal 185psi
Minimum 135 psi
Max. Variation 28psi
Measured at 250 RPM and WOT. Post your results when you finish testing pleaseeeee.
Shut yo ass up nugguh..
ReginaVagina
Old Jul 30, 2007 | 05:23 PM
CRX-Si-Guy's Avatar
M-M-A
Originally Posted by Hybrid_eg
Normal 185psi
Minimum 135 psi
Wait, you can check compression at 250 RPM or was that a typo? My compression came up 75, but im realllly confused.
Old Jul 30, 2007 | 05:25 PM
Hybrid_eg's Avatar
Your starter should be kicking the engine around at 250 rpm. Your compression is 75-75-75-75?
ReginaVagina
Old Jul 30, 2007 | 05:29 PM
CRX-Si-Guy's Avatar
M-M-A
Yup, 75-75-75-75. I revved up also. Im not sure of the RPM's i was up to though.
Old Jul 30, 2007 | 05:30 PM
Hybrid_eg's Avatar
WOT with ecu fuse and spark plugs out, right? Wow...Bad numeros. Time for a rebuild. Rangcrx will tell you NAPA does good machine work for cheap.
ReginaVagina
Old Jul 30, 2007 | 05:32 PM
hatchback1994
did u let the motor turn over at least 5 rotations?
Old Jul 30, 2007 | 05:43 PM
CRX-Si-Guy's Avatar
M-M-A
Oh shit, wait a minute. yes i did let it crank over, and all 4 are reading 75. I'm gonna test it again tomorrow and read it again. Shit man its one thing after another with this damn car.
