eBay Intercooler Test
Old Jul 30, 2007 | 09:55 AM
Alpha's Avatar
Default eBay Intercooler Test
All testing was done by Buschur Racing Take the test for what it's worth. A lot of work goes into this type of test. Hope to see Lancerman (Jerry) do some testing in the next couple months
Originally Posted by davidbuschur
Here you go, we finally did it. I hope everyone is happy now. I know I am.
My car is on the dyno making huge power, 640 whp with the new HTA35R on it. We have our Race FMIC on it which I say is the best FMIC you can buy with your hard earned money. The tempurature today is 62 degrees F in our dyno room.
I made a bunch of pulls this morning and the car was making within 1-3 hp on the last few of 640/511 torque.
When I got done I decided to leave the car on the dyno and put on the Ebay intercooler that is a copy in appearance to the AMS FMIC.
My car is running C16. I am using NO air temp correction for fueling other than when the air is BELOW 50 degrees F. So if the air temp goes UP the fuel stays the same. I am using no timing compensation for anything either. What I am telling you all is the map is the map, it is running what I told it to and not making adjustments.
The last pull I made with our Race FMIC was 643 whp and 511 ft lbs of torque. I MADE NO CHANGES. I left the dyno, had Ted bolt on the new intercooler and came back when he was done.
Here is the important data:
Air temp after the intercooler at the start of the pull, 62.60 degrees.
Air temp after the intercooler at the end of the pull, 69.80 degrees.
Increase in air temp 7.2 degrees.
Peak boost was 40.3 psi.
We then bolted on the Ebay special that is an AMS attempted copy. Absolutely NO changes were made to anything other than bolting on the I/C.
Car made 633 whp and 505 ft lbs of torque. So not a bad loss at this HP level.
Here is the BAD part.
Air temp after the intercooler at the end of the pull, 122 degrees!! That is an increase in air temp of 59.4 degrees in a single gear pull!
Peak boost went up which I find strange as it hit 42.1.
The knock count went up considerably with these higher air temps. To run the car safely I would need to pull atleast a few degrees of timing.
**So in summary the intercooler with 2 more psi boost made 10 less whp than our Race FMIC at that is at big HP levels. The problem is the intercooler is NOT EFFICIENT AT REMOVING HEAT. Which is what it is there for. I am betting the stock FMIC is not much worse than this. An increase of 59.4 degrees is absolutely HUGE in a single gear pull. On a summer day or road race/autocross situation this intercooler would absolutely SUCK.
Bottom line is, you get what you pay for and buying one of these I do not think is a good investment of your money.
2nd test didn't come out to good.
I had also bought a new LARGE FMIC to test awhile back. This is the really big one with the 3" inlet/outlet.
First off it does not fit with our FMIC plumbing and it has not mounts. It's just a big Ebay intercooler.
We had some 3" to 2.5" couplings and attempted our best to put it on the car. It was fine at 25 psi but would not stay on at 40 psi. Looks like it is a turd anyway so here is what I could get for data:
Air tempurature after the intercooler at start of test, 64.40 degrees
Air tempurature at end of test (test ended at ONLY 6200 rpm as the pipe blew off 2 times) 82.40 degrees.
Peak boost pressure was 41.58 psi.
The test of our Race FMIC were run from 3,000 rpm to 8,000 rpm. Temps were taken at the start and end of the pulls for all these tests.
So even this very large FMIC increased air temps 18 degrees and it wasn't even close to being a full pull. For comparison the smaller ebay intercooler from start to 6200 rpm had increased to 86 degrees.
This concludes our Ebay intercooler testing. I have both of these for sale or you can buy a real intercooler and call us to order the Race FMIC.
Our Time Attack car last season was fitted with our 20g-9-5, of course since it is small it is not the most efficient turbo and makes quite a lot of heat when pushed.
I have our datalogs from Summit Point Time Attack pulled on my laptop from last year.
We were out for a session which took 6 minutes and 30 seconds. This is a warm up, 3 full runs and cool down lap.
The car had out Race FMIC on it. Boost levels were a peak of 27.3 psi. No alky injection, no water sprayers. Just turbo and our FMIC.
The very beginning of the log shows AIT's of 104 degrees F. (so it was pretty warm outside combined with engine bay heat and such I suppose) The air temps at part throttle boost around the track, through corners and such would go up to around 107 degrees F. Robert had a few decent long straights. The car would accelerate up to 118 mph on one where the AIT's reached 111.2 F. Then he would slow down for a corner and they would remain close to 111 F. The next long straight he would start the long pull with AIT of 109 f and at the end of the straight he was doing 124 MPH with AIT's of 116.2 degrees.
This was the very first lap, a warm up lap.
Now, looking at the 3rd all out lap the air temps are holding a steady 120 degrees. On the first straight the car hits 122 mph, so you can see he is pushing harder. The AIT's at the end of this is 123 degrees. The longest straight shows vehicle speed at 130.6 mph and intake air temps up to 125.6 degrees.
The part of this that you should find impressive is that road racing is going to build a lot of heat and keep the intercooler hot. Here is an example of a car with a fairly small turbo running 27 psi of boost on a very warm day. Started a Time Attack session with AIT's of 104 degrees and after beating the car for 6 minutes and 30 seconds the AIT's only saw a high peak of 125.6 degrees.
That is some damn good heat control right there. A rise of 21 degrees.
The two Ebay intercoolers we JUST tested on a 60 degree day with starting temps of 60 degrees gained almost 60 degrees of intake air temp IN A SINGLE GEAR RUN.
I hope this will finally show there is a difference.
The power on my particular car even with the Ebay stuff on it is decent. BUT, if you tried to run this intercooler on ANY OTHER vehicle with air temp correction the results would be a lot less favorable in the HP department. The factory ECU would kill the car with fuel and timing adjustments as would any other car that had corrections for air temp turned on.
I chose to test the intercooler without these corrections to let it just do what it could and show the real truth behind the products.
Truth is, had the intercooler done really well, I would not have posted any of this information. Luckily for me it performed poorly in the cooling department.
Thank you and have a great day.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jul 30, 2007 | 10:03 AM
Alswizzo's Avatar
The Underdog!
thanks for the info, i was always curious if those ebay intercoolers were any good.
Old Jul 30, 2007 | 10:58 AM
Gixxer's Avatar
Hide your daughters
Good info, I'm glad I got rid of my eBay junk kit.
Old Jul 30, 2007 | 11:23 AM
F4A22's Avatar
Old School
My suggestion is build your own intercooler if your on a budget.Juniors mirage has a custom built intercooler that we ordered the core and endtanks from a reputable company.My personal experience i bought a ebay intercooler and it wouldnt hold over 17 psi.I contacted the company/seller about thier "40" psi rating on the ad and they blamed my pipes and clamps.I tried using t bolt clamps,3/4 inch thick RRE clamps, and good coupler material from amazon with no fix in site(it was blowing at the intercooler inlet not the pipe).I ended up having better success with a used stock srt4 core which never blew off even at 27+psi.
Old Jul 30, 2007 | 05:54 PM
00ACCORD's Avatar
SPEED DEMON
How are those GODSPEED intercoolers? anyone know?
Old Jul 30, 2007 | 06:40 PM
My Honda Is Slow's Avatar
No really,....it is
ok but what about the average street driver boosting a honda on say 6-15 psi? do you think the ebay intercooler would make that big of a difference? i have read that quite a few people on here have ebay/turbo xs/xs power, etc intercoolers and they have no issues with them.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jul 30, 2007 | 07:59 PM
Old Renegade's Avatar
Cool Runnings
from what i see they were mainly focusing on air temp. the hotter you run the less performance you get. good info by the way.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jul 31, 2007 | 09:30 AM
FC_V8's Avatar
cool thread......
Old Jul 31, 2007 | 09:40 AM
F4A22's Avatar
Old School
Yea but i bet thier numbers would greatly improve if they upgraded.Heatsoak kills turbo cars power after a couple of passes or pulls.If your serious about making big power and maximizing you setup cheap shit doesnt cut it.
Old Jul 31, 2007 | 09:44 AM
Ink's Avatar
Ink
Changes names a lot.
i personally think that test doesnt prove anything. no i dont use an Ebay intercooler as I dont drive a car, but who drives around on 40 lbs of boost? who drives on anything realistically over 20lbs or so? you dont need that much for the street, and if you want more you can up it, but id say the average turbo daily is about 7-8 or 9-11 lbs IMO
