speedo going crazy in 99 ex HELP!
Old Jul 26, 2007 | 06:55 AM
chriscarr's Avatar
Default speedo going crazy in 99 ex HELP!
speedo jumps like crazy while accelerating .... like up to 100+ sometimes... and sometimes it stays at 0... started happening last nite... is it the speedo sensor?? and help appreciated
Old Jul 26, 2007 | 06:58 AM
-faded-'s Avatar
infraction king
what is the car doing when this is happening? sounds like the vehicle speed sensor may be bad.
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Jul 26, 2007 | 03:23 PM
chriscarr's Avatar
car is accelerating/decelerating as usual... rpms work fuel gauge temp everything but the mph is now stuck at 0... at ANY speed i go
Old Jul 26, 2007 | 03:29 PM
EXtreme7200's Avatar
loves beer!!!!
check your ecu...its probably the vehice speed sensor most likely
Old Jul 27, 2007 | 09:36 AM
Derka's Avatar
TR Balla Donor Supreme
YOu can also check the speedo/alt. fuse under the dash, its a 7.5 amp. If it blows that will happen to your speedo as well
1998 crv daily beater
Old Jul 27, 2007 | 02:55 PM
chriscarr's Avatar
checked and changed the fuse... still doing the same thing.... howmuch is the speed sensor? and it is difficult to install
Old Jul 28, 2007 | 09:01 AM
nisson93's Avatar
change the speed sensor there not that much and usually the problem i had this happen to me like 4 time it was the sensor everytime
