wiring vtec need help
Old Jul 25, 2007 | 07:27 AM
luvsracin87's Avatar
turbo hhhmmmm?
Default wiring vtec need help
ok guys i am going to be wiring vtec in to a non vtec car soon and i have nice write up on how to wire in in a non vtec harness How to wire vtec - Hondaswap i know the GRN/YEL wire comes from the vtec sel. but the only question i have is where does the BLU/BLK wire come from in the engine bay?????
i am very mechanicly inclined so plz dont say "oh you cant do that just have some else do it" this is just the first time i am messing with vtec
thank you in advance for any help
steve
Steve: (813) 810.4146 <~ call or text
Old Jul 25, 2007 | 11:47 AM
turbo hhhmmmm?
any one?
Old Jul 25, 2007 | 12:57 PM
elitist's Avatar
TR Balla Donor Supreme
Comes from the pressure switch.. if you are putting a jdm motor in it won't have a pressure switch.. the pressure switch is the green plug on the bottom of the vtec solinoid.
Old Jul 25, 2007 | 01:01 PM
turbo hhhmmmm?
yes its a jdm type-r b18c..........so i will only have to run the GRN/YEL wire to the ecu?
Old Jul 25, 2007 | 01:06 PM
elitist's Avatar
Yuppp rep?
Old Jul 25, 2007 | 01:41 PM
turbo hhhmmmm?
repped!!!
Old Jul 25, 2007 | 01:47 PM
elitist's Avatar
thank u!
Old Jul 25, 2007 | 05:26 PM
60-1EK's Avatar
Engineer at the source
Yeah, but what ecu are you going to run? If you are running the USDM ecu with the JDM motor setup, then you will have to jump the vtec pressure switch wire with the vtec solenoid wire.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 25, 2007 | 07:42 PM
elitist's Avatar
Si si senor, hopefully he just has a whole JDM swap though
