removing bitch pin! good info
Old Jul 23, 2007 | 06:14 PM
My Honda Is Slow's Avatar
No really,....it is
Default removing bitch pin! good info
i have seen alot of people asking about this and having problems with it, on and off of this site. maybe some of you have already seen this or founf it on the internet but i thought it might help some people on here, maybe make it a sticky or something who knows. enjoy
also i got it from this site off google.
http://images.google.com/imgres?imgu...%3D1%26hl%3Den
Removing the "bitch pin"
Without using a hammer
Originally written; March 10, 2007
To start off;
You shouldn't be bashing on something attached to your transmission with a hammer!! The transmission case is aluminum for gods sake!
I'm tired of people thinking that removing the transmission linkage roll-pin warrants calling it a "bitch pin". However, it's the commonly used name, so that's what I'm going to call it.
I took the photos with the linkage out of the car due to not being able to shoot good photos under the car (I don't have a lift). The process I'm going to outline is exactly what I do under the car while it's on jack-stands.
All the photos are "clickable" to a larger view.
You may have to buy a couple tools, but nothing custom or big-buck!
Here is a photo of all the tools you need other than a good size C clamp. You can buy everything at Sears!!
There is nothing special about the two sockets except for the fact that they should be large enough for the bitch pin to fit inside. Both are 1/4" drive sockets.
The assortment of 1/4" "bits" are nothing special and I got them at Sears. You are going to use two of the allen head bits and as such may be able to find a smaller assortment for less money.
That's the bitch pin on the lower right.
Now in the next two photos you can see the key to how this all works;
You want to first off find one of the bits that slides inside the bitch pin. In the right hand photo, I've slid the bit inside the bitch pin.
The whole reason for doing this is that the bit is supported while you put the force of the C clamp on it.
Now get under the car, push the rubber boot out of the way, and remove the circular clip that prevents the bitch pin from falling out (like it's really going to just fall out).
Put the car in third gear. By doing this the shift rod coming out of the transmission moves toward the rear of the car and gives you more room for the C clamp.
From the top side, put that allen bit into the bitch pin (it stays there due to fitting within the bitch pin) and grab your short socket.
Use the C-clamp as shown in the right hand photo to press the bitch pin downward, into the short socket.
Once again, this all works under the car if you put the transmission in third (or first)!!!!!
Now you run into a little problem in that the allen head bit will bottom out before the bitch pin is all the way out and there doesn't appear to be anyway to remove the allen bit.
Now you want to use the largest size allen head bit that is slightly smaller in diameter than the outside diameter of the bitch pin. Insert it in the hole at the top and use the deep socket as shown in the photo on the right.
Finish with the C clamp and the bitch pin will fall free.
At this point, I'd recommend you just remove the main shift rod (the one with the bitch pin) for a little prep that makes it easier when putting everything back together. It's just one bolt at the base of the shifter and it will make it easier in the long run!
With the shift rod out of the car, use a hammer (dang, I really didn't want to say that) to tap the bitch pin partially in place. It should be so that when you install the linkage, it's going in from the bottom. (just easier to get the C clamp in there when done in this direction)
You want it so that it's in place, but not so deep that it pokes into where the transmission rod has to go.
If it's too deep, use the large allen head bit to move it outward.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jul 23, 2007 | 06:26 PM
EGKID's Avatar
You have saved major headaches for the future. I tried to give you rep but I need to spread more.
Ricky
Old Jul 23, 2007 | 06:48 PM
No really,....it is
yeah i figured it would help someone somewhere. i have always used a hammer and either a bolt from my fender or a punch and it comes right out. but this is an awsome second idea. everyone has their own way of dealing with it but this guy actually took the time to do a write up on it.
Old Jul 23, 2007 | 07:09 PM
rangcrx's Avatar
engine building &best
wow old new but cool i been doing it that way for 10 years : o )
i love AUTOZONE
Old Jul 23, 2007 | 07:12 PM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
thats cuz your the man nukka ^
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Jul 23, 2007 | 07:23 PM
rangcrx's Avatar
your so right,damn i am the man damn but then again its not hard to be the best at something whenyour so good at it!!
i love AUTOZONE
Old Jul 23, 2007 | 07:29 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
i coulda used this like 3 weeks ago damnit lol
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Jul 23, 2007 | 07:58 PM
FC_V8's Avatar
nice write up.....repgiven......
Old Jul 23, 2007 | 08:12 PM
CodenameAcura's Avatar
Slow Is Good
I just used and 8mm punch and a hammer and it comes out no problem lol
-13 Suburu Impreza WRX
-10 Honda CBR1000RR (for sale PM me)
-07 Nissan Frontier CC (sold)
-99 JDM ITR DB8 (4dr whore) sold
-98 Acura Integra GS (Go Slow) sold
-04 Ford Ranger Ext Cab Step side (traded)
-03 Kawasaki KFX400 (sold)
-05 Kawasaki KFX400 (sold)
-02 GSXR 750 (sold)
-04 Triumph Daytona 600 (sold)
Old Jul 23, 2007 | 10:57 PM
custom240sx's Avatar
DC Crew Member #1
repped
