Fuel Air Meter?? DC5
My car is throwing the code fuel air meter on an 02 RSX. Does anyone have any idea where this is located or what it means? Anyone had this same problem?
Jacklyn <3
Jacklyn <3
I want to say that's the primary O2 sensor. What was the actual code number?
http://www.myspace.com/terry_ho
Yep the primary O2 sensor is bad. It's an easy fix.
-P1166 Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction
-P1167 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction
Yep
Yep
Did you change the sensor with an oem honda part ?
