B series tranny install help!!!
Old Jul 19, 2007 | 11:22 AM
CodenameAcura's Avatar
Slow Is Good
Default B series tranny install help!!!
Trying to reinstall a new tranny in my gsr. Got the old one out but I am having a heck of a time trying to get this one back in. I am by myself so this is a task and a half. Anyone have any good tricks to installing a tranny by yourself? I just can't get it to line up correctly I guess. Help please! Need to finish this today so I have a car to drive!
-13 Suburu Impreza WRX
-10 Honda CBR1000RR (for sale PM me)
-07 Nissan Frontier CC (sold)
-99 JDM ITR DB8 (4dr whore) sold
-98 Acura Integra GS (Go Slow) sold
-04 Ford Ranger Ext Cab Step side (traded)
-03 Kawasaki KFX400 (sold)
-05 Kawasaki KFX400 (sold)
-02 GSXR 750 (sold)
-04 Triumph Daytona 600 (sold)
Old Jul 19, 2007 | 12:20 PM
alwayzblazed's Avatar
Get'em Started Early
I did mine by myself and i used a jack and a piece of 3/4 wood to lift and then its basicly strong arming it cause that bitch is heavy.Jinggle it turn it
Also did u use the alignment tool on the clutch,that is important,it might also be the half shaft needs to be aligned. well thats all i can think of
Old Jul 19, 2007 | 02:40 PM
My Honda Is Slow's Avatar
No really,....it is
yep as said above, set it on a hydrolic jack and roll it up under the car and jack it up and stand over the pass side fender while jacking it up with your foot. (i know it sounds retarded but you will see when you do it) then just grab it and align it in. i have had to do this several times, kinda sucks but it will get the job done for sure.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jul 19, 2007 | 04:59 PM
civicized's Avatar
Get some help. It takes at least one man and a medium sized boy. Also, what he said - alignment tool a must when installing the clutch disc.
Old Jul 19, 2007 | 06:53 PM
FC_V8's Avatar
well.. i've always had problems with the FUCKEN trannys installing them in.. there soo fucken heavy.. but now i just use my engine hoise and jack it up then aline it perfect and then it just slides in.. G/L on yours though.
Old Jul 19, 2007 | 06:56 PM
60-1EK's Avatar
Engineer at the source
Clutch alignment tool FTW. I just slide under the car, dead lift it onto my check and up into the car it goes. Wiggle wiggle, dow pins lined up...wiggle. Install some bolts while laying down there to hold it temporarily and rest is history.
I think I have done this to my car about 40 times now in the past couple years.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 19, 2007 | 06:59 PM
SmokinS13SR20's Avatar
That ginger...
Originally Posted by 60-1EK
Clutch alignment tool FTW. I just slide under the car, dead lift it onto my chest and up into the car it goes. Wiggle wiggle, dow pins lined up...wiggle. Install some bolts while laying down there to hold it temporarily and rest is history.
It's fun doing it this way, atleast I think so
Get's a good workout.
I had to do it like 4 times on one car.
My buddy had someone else work on it while I was at work, she was dumping oil out of the rear main seal.
Dam FWD Auto tranny...
Old Jul 19, 2007 | 07:22 PM
Tightcivicexboii's Avatar
Honda Gear Head
Thats a way that i used, another way is too. If you have an Engine hoist. Get the tranny chained up and in the air within the engine bay on the pass. side. Jack it up towards the spot, while you get under it to position the drive shaft into the clutch disc and flywheels teeth. It's better if you have ghood light in the area and another person above trying to accomplish the same thing as you. Make sure your dowel pins are set and it should be done on that same day. Ghood luck tho. Use help.
No project currently. Getting my ASE Certifications Completed.
Old Jul 20, 2007 | 06:13 AM
civicized's Avatar
You've changed your trans on an average more than twice a month for the last couple of years? You gotta be beatin' on that car.
Old Jul 20, 2007 | 06:54 AM
dscivicdx's Avatar
TR Balla Donor Supreme
lol... or making way too much power!
