ECU trouble code problems.....getting aggravated!!
ive got a 90 civic dx with a b18b1 in it. i rebuilt it over the weekend and installed it last night. started right up and drove it too work today. only problem is its got an 0bd0 manifold on it and the iac is fucked so we shoved tape into the holes in the throttle body too idle it down. ghetto is not my style but its a temp solution. none the less breaking the motor has gone fairly well. drove fine too work with no problems. once i get out of work i start it up and begin too drive and once it hits 2500rpms it fucking wigs out. the only thing i can compare it too is spraying and the bottle being closed and loading up on fuel, except this is more violent. instead of going home i went too TeamCalloways house and he test drove it too see what exactly it was doing. the car was off for like 5 mintes and it didnt do it. so im like wtf. anyways i left like 30 minutes later an it stared doing it again, this time he heard it. it seems like the injectors are comming undone, but theyre not.
no for my problem. we checked codes but we dont know the DA codes.
im getting a 7 and 24 i think. ecu is a pr4. i think its virgin.
it goes:
flash flash flash flash flash flash flash
pause
fllllaaaaaaaaaaash
pause
fllllaaaaaaaaaaash
i found some codes online but no 24.....wtf? what is causing my car too do this? help me please.
it goes:
pause
fllllaaaaaaaaaaash
pause
fllllaaaaaaaaaaash
exactly. i searched for a while and still nothing. in my pm6 in my other civic i had it flashed 10 times for code 10.....could this pr4 ecu be one loneg flash for code 10? theoridically speaking, itd be throwing codes: 7, 10, 14. wiring and electrical is my weakness. im trying.
1. Check your codes like you have been doing.
2. Resolve your codes
3. Diagnose from there...
i think the ecu has been tampered with. my O2 sensor is not plugged in and is not throwing a code. mtber, am i correct on it throw 3 codes (7, 10, 14) or is it 2 codes (7, 24)?
Sounds like 7, 10, 14
If that is the case, no wounder your car is running like shit...
