need help 96 ek with a d16z6
Old Jul 15, 2007 | 06:24 PM
ekdriverN/A's Avatar
Default need help 96 ek with a d16z6
i swapped a d16z6 into a ek got the conversion harness and a p28 ecu the car turns on but when you give it gas it wants to stall out doesnt want to pass 1500 rpms before shutting off
Old Jul 15, 2007 | 10:31 PM
sxecrow's Avatar
EG2 CRX
I never trust those conversion harnesses. I'd get a OBD1 ecu, injectors, and distributor. Try that if you can borrow a buddies.
Old Jul 16, 2007 | 07:15 AM
have a odb1 computer and the dizzy has the casing of a the d16z6 but with the internals of a 96 soo that the plugs can pulg in.the conversion harness was made by phearable he is a reliable seller and his products as well
Old Jul 16, 2007 | 10:39 AM
coleon's Avatar
RedNeck Refab.Inc
check out your dizzy wires and make sure your pin out at ecu matchs what you have up top.
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old Jul 16, 2007 | 06:01 PM
tt
Old Jul 17, 2007 | 01:00 PM
tt
Old Jul 18, 2007 | 10:22 AM
tt
Old Jul 18, 2007 | 04:23 PM
Hybrid_eg's Avatar
i like the blue ones
Contact 60-1 EK on here. He's a boss when it comes to harnesses and EVER reliable adapters.
Shut yo ass up nugguh..
ReginaVagina
Old Jul 18, 2007 | 04:58 PM
mtber's Avatar
obd1 ecus can be run with an obd2a/b distributor, injectors, alternator etc.
Old Jul 18, 2007 | 05:00 PM
mtber's Avatar
Originally Posted by Hybrid_eg
Run the full OBD 1 distributor and buy one of these bad boys.
Rywire - Online Store
Our harnesses are the same exact item rywire sells.
He does not need an obd1 distributor to run an obd1 ecu.
60-1ek sold jkobd to rywire, hence he does not make harnesses anymore.
